green03
i run whatever pressure it takes to have an even contact patch to the road.... look at your "road marks" on the tires. If it looks like the edges of the tires aren't contacting the road much use less air. if the edges (side of edges) of the tread look like they are being scuffed then you need more air. you will see a different pressure needed between the front and rear tires....
Matt R
Matt R
