VIN info
UncleDJ
Central OH
I'd like to identify my axle gear ratio...I think it's a 3:73 but want to confirm.
Where can I get info to understand the VIN for my 2014 Expy?
U
UncleDJ
Central OH
Never mind....found it....it is a 3:73
On that subject...how do I tell if it's a limited slip?.....I'll keep lookin'
Code 16 looks like 373, non limited slip.
Boostedbus
Maryland
You can always jack it up with both rear tires off the ground and spin a rear tire by hand..... if they both turn the same direction then it is limited slip and if one spins opposite direction than the other then it’s an open carrier rear differential. If it’s a limited slip you can also count the driveshaft turns to one turn of the rear tires while it’s jacked up .... 3.73 should be just shy of 3-3/4 driveshaft turns to one complete tire turn
lvcjt702
Lost Wages
Whats the axle code on your door sticker?
Sent from my SM-G935P using Tapatalk
