What suspension components causing abnormal tire wear?!
jayzce
Manila
My rear inner tires are worn out specifically the left rear side. Right side seems to have the same issue but the left seem to be worse. I have 24" wheels with 305/35/24 tires and it's on it's 3'rd year on my truck. Additional info on my truck is that it's 79k kilometers. If mileage is another info that would provide details if my suspension are worn out.
Where to start of in diagnosing the cause of the tire wear? Shocks? is there a known weak link on the 2010 Expeditions rear suspension that would cause the problem?
Flexpedition
midwest
Excessive wear on the inside of rear tires (on our independent rear suspension) is most often too much toe out. Could be worn bushings. When is the last time its been aligned or tires rotated?
gixer2000
Retrofit or Bust
Massachusetts
A 4 wheel alignment and rotation at every or every other oil change would probably cure this
