stamp11127
These are a few of the inputs/outputs:
Defrost Relay Ground
Park/Headlamps On input
Interval Delay Input
Park Sense
Wiper Hi/Lo Relay
Run/Park Relay Control
Windshield Wiper Mode Select
Front Washer Pump
Door Ajar Indicator
Seat Belt Indicator
Left Front Door Ajar input
Left Rear Door Ajar input
Right Front Door Ajar input
Right Rear Door Ajar input
Lift Gate Door Ajar input
Illuminated Entry Input
Brake Pedal Position Input
Low Range output to PCM
Hall Effect Power
Rear Speed Sensor Input
4x4 Mode Switch
Torque on Demand Relay
Front Speed Sensor
AWD Engaged Output
Neutral Sense Input
ABS Active Input
Rear Washer Pump Control
Low Washer Fluid Lamp
Rear Wiper Hi/Lo/Park Sense
Rear Wiper Up Relay Control
Rear Wiper Down Control
Rear Wiper Switch Control
Washer Fluid Level Switch
Courtesy Lamps
Power Windows
Instrument Cluster
Anti-Lock Brake System
All Wheel Drive
Safety Belts
Ignition key Warning
Restraints Control Module
Rear Window Defrost
Radio - (Premium Sound 2001)
and I'm sure there are a few that I've missed.....
I'll update the list as I run across additions to it.
Park Sense
Wiper Hi/Lo Relay
Front Washer Pump
Door Ajar Indicator
Seat Belt Indicator
Hall Effect Power
4x4 Mode Switch
Front Speed Sensor
AWD Engaged Output
Neutral Sense Input
ABS Active Input
Courtesy Lamps
Power Windows
Instrument Cluster
All Wheel Drive
Safety Belts
Rear Window Defrost
