Hello,
So we have our 30' outback which is actually more like 34' tip to tail. With the current WD setup it only uses friction plates for sway. I had upgraded to dual friction plates but still more play than I want.
So I've upgraded my tire to Yoko Geolanders G015. If you haven't looked at these tire do. In the 20" size they are an extra load tire so a little stiffer and can be pressed to almost 50#. That will help with any sidewall play I was getting from the Bridgestone (junk).
Next I want to upgrade hitches. My GVTW is Approx 7700#, 770 tongue. I want to upgrade to the Blue Ox sway pro. Now I've found a couple locally used, maybe 1 season total each and was wondering which bar weight I would want.
I was originally going to go with the 1000/10000 setup, but found a 1500/15000 setup for a better price. My question is if I would be ok with the 1500# bars or would they be too strong and unload the rear of the truck. The 750/7500 model would be undersized.
Thanks for any advice. I liked the look and design of the blue ox, thought about equalizer but heard issues with noise. Can't be any worse than two friction plate sways cranked all the way up and going through a rest stop / gas station.
For what it worth, I have the air suspension.
Thanks again,
Matt
Thanks again,
Matt
