What's the most - off set can I go ?? Opinions
scoot0073
Georgia
I'm undecided if I want 20" wheels or stay 17".
But one thing for sure I want is to run
35 12.50 tires.
I really want a negative off set like the wheel in the picture.
But I'm sure more negative off set I run the more the tire is going to run. Which I'm OK with trimming the valance and removing the step sides.
Any ideas ??
Mine below
Sent from my Pixel XL using Tapatalk
scoot0073
scoot0073
Georgia
Yes that looks good too but the problem is with these stock wheels when we go to Mud Fest no matter how much I play n mud it will never get on the body ..
I was thinking like a -22 off set like in the picture above would put the tire out past the fender but at the same time that would probably cause me to have to cut more than just the valance ??
Or another option is to buy 2" wheel spacers .
But dropping $2,000 for wheels n tires I don't wanna end up with something I can run BC of to much off set
scoot0073
scoot0073
Georgia
I got my 3.5/2.5 lift in Friday so now I gotta figure out the wheel thing..(banging head)ad4a6686704774ceb8f04bcb4cc4e640.jpg
Gruz7
North Smithfield, RI
You won't be able to go higher than a 33" tire with a 12" wide wheel I'm pretty sure
scoot0073
scoot0073
Georgia
Yea .. I was thinking same thing maybe 20x9 ?? With 35's would work ?
scoot0073
scoot0073
Georgia
And thank u Gruz7 for your input
Gruz7
No prob! I think those would work.. mine are 17x9 and with the 35s they rubbed like hell on the inner fender and valence, I had to trim in the inner and bang in a pinch weld on the firewall and the valence I just hit with the dremel
scoot0073
scoot0073
Georgia
Well if u got 35's with -6 off set wheels and u had to do all the above then maybe I shouldn't try to go past -6.
But I'm definitely going 35's as that will add about another 3 inches to the lift on top of the 3.5/2.5 kit I just got.
Gruz7
That was my thinking too and yeah the more negative offset you go with the more rubbing problems you're gonna have so I only went to -6
cfarnAK
