white smoke
Discussion in 'New Member Check-In' started by renee, Apr 15, 2012.
  1. renee
    renee Member
    Apr 15, 2012
    north carolina
    I just replaced 4 out of 8 spark plugs on my 99 expedition and i started the truck to it running really bad and white smoke coming from the exhaust the smoke smells like gas and my engine light is now on any suggestions on what it is? The plug for a computer to hook up and read the codes is broke so I can't just take it in
  2. TexasAngel34
    TexasAngel34 Full Access Members
    1,591
    44
    Jan 12, 2012
    Peyton, CO
    Welcome to the site, im sure someone will help with the issues....
  3. sgtowing
    sgtowing Super Mod, Supporting Members Supporting Member
    5,507
    367
    Jan 30, 2011
    Valrico, Fl
    Welcome. White smoke is a sign of coolant getting in the combustion chamber, usually a sign of a head gasket leak.
  4. renee
    renee Member
    Apr 15, 2012
    north carolina
    but wouldn't the smoke smell sweet instead of like gas? The third spark plug i had to use a chaser on do u think it is the oil i used to lub the chaser?
  5. toms89
    toms89 technical advisor
    5,172
    423
    Mar 13, 2011
    MD
    I would say you have a dead cylinder or two if it is running badly after plug change. If it smells like fuel you likely are not getting spark.
    Are you sure all cops are plugged in??
    Did you gap plugs properly? Are spark plugs firmly seated and torqued?
  6. renee
    renee Member
    Apr 15, 2012
    north carolina
    i gapped them all at .054 like the book said would that cause the smoke if its off?
  7. toms89
    5,172
    423
    Mar 13, 2011
    MD
    Not if its in the ballpark...
  8. toms89
    5,172
    423
    Mar 13, 2011
    MD
    What year expy?
    Any issues prior to plug change?
  9. renee
    renee Member
    Apr 15, 2012
    north carolina
    ok i will go back thru them the truck had no problems like this before hand thank you for your help
  10. toms89
    5,172
    423
    Mar 13, 2011
    MD
    Generally white smoke is sign of coolant in combustion chamber but I am going on the basis that the vehicle was ok before the plug change.
Share This Page
