Jimmatt
my washer stopped squirting for the front windshield but it still squirting the rear in both positions Where does one look for the solution for this problem
97 expedition 5.4
97 expedition 5.4
The pump is working the problem is when I try to spray the front window the rear will spray instead of the front??Check the fuse first - see the sticky in the electrical section on how to check them. The pumps are located at the bottom of the washer tank. If you hear the pump running when tell it to squirt look for leaks in the lines.
