Window and door lock
Tonka
Columbus,Ohio
1. Drivers window: when pushing up on power button window rolls down. 2. Power door lock on back door stopped working have to lock and unlock manually. Any suggestions thanks in advance.
Yupster Dog
Super Moderator
Super Moderator
Did you just replace the window motor? The wires coming from window motor itself can be reversed at the end.
The back door lock actuator is likely the culprit for the power lock you can undo harness and test to see if it is getting power when the lock button is hit.
Tonka
Tonka
Columbus,Ohio
Thanks, nope I haven't done anything to the window at all it just starting acting up.
Hampton, VA
Possible bad switch or switches
Sent from my SM-G965U1 using Tapatalk
Bobnoxious
Dearborn Michigan
I was having the same issue in my 2013. I took the vehicle to the dealer for the transmission recall, and mentioned the issue. They refreshed the BCM(Body Control Module), and it resolved the issue.
Sent from my SM-N960U1 using Tapatalk
Tonka
Tonka
Columbus,Ohio
I have a 2013 as well, I saw that info about the transmission recall. Did your transmission start messing up or did they do it because of the recall?
Bobnoxious
Dearborn Michigan
I was experiencing irregular shift behaviour, during normal driving. The update seems to have resolved - but only time will tell.
