Gasoline question
Adieu
SoCal
Thanks MrJ .... I should have looked that up myself, too busy putting miles on the old gal right now (weak excuse). Although the way I read that is not to use less than 87 in higher altitude areas, not a total ban on using less than 87 octane.
Gas is good price in Sturgis tonight
Sturgis Michigan
Imagine how cheap gas will be when electric cars start rolling out in a couple years
No
The things is 85 & 86 are sold ad regular IN HIGH ALTITUDES (something about atmospheric pressure affecting how stuff runs?)
And imho Ford's just doing CYA lawyer speak for "don't use anything we didn't test and then expect us to cover it with warranty if you mess it up".... it doesn't actually mean anything conclusive
Utah 85 ran good and with quite solid MPGs for a couple of tanks for me
P
Plati
No
Yes ... Not No
That's what it says (in writing). I think you have it backwards. Higher elevation needs higher octane not less. Sure it probably normally works ok but not advised for marginal cases.
ManUpOrShutUp
I haven't seen 86 octane in many, many years. What is it in Nebraska now? About 1995 or so? :D Those gas prices are pretty sweet though. I'm paying ~$2.50 in NJ and ~$2.75 in PA.
Adieu
SoCal
Yes ... Not No
Nope
P
Plati
I guess the 5.4L Expy can run on E85, although I don't recall seeing the Flex fuel badge anywhere on the vehicle. I think it has the yellow band around the gas cap. I've never done it and don't think I will. You get a big reduction in gas mileage and probably power?
https://www.fueleconomy.gov/feg/noframes/34325.shtml
ExplorerTom
Correct. In most of Colorado, 85 octane is the low grade octane rating. Premium is only like 91 octane- instead of 92 or 93 at sea level.
The lower atmospheric pressure results in lower combustion chamber pressures (even with forced induction) than sea level. Therefore you can get by with less octane (less ability to prevent against pre-ignition, which can be caused by too much pressure).
I’ve run several tanks of 87 here at altitude just to see if I can feel a difference in power or mileage or anything. I noticed no difference- other than paying more each time I filled up.
ChrisOIFdoc
Rio Rancho, NM
To understand is to know a bit about refining......Superlow Regular came about by lowering the required standard to allow the selling of the undercrop, or the material that tests at just under the 87 minimum once the additive package is selected and installed.
If refiners can sell the junk, it produces, it allows more space, more barrels refined....
Right now there is a huge delta in pricing....and consumers are getting gouged since the undercrop is now selling at one half the price of 87 to wholesalers.....the 50 cents might seem like a great deal....but the station is actually making more, MUCH more per gallon from it....for now.
This stuff comes into play when you often buy cheap, off brand gas and explains why often, it's a tier 1 fuel rated higher in octane that the sign shows!
jeff
First you had a pic of my wife riding a bike for your avatar.....now this one? I need to have a talk with my wife about her choice of clothing!
P
Plati
Does it depend on what engine you have and if you're towing? I thought the EcoBoost advised high octane in the mountains while towing? I might be conflating things here and applying something across the board that is case specific.
Ok ... I think I've learned something new here , that you can get away with lower octane gas in higher elevations. That's what discussion with other people is all about. Not winning an argument but education.
I'm thinking you can get away with lower octane at elevation, but you will have less power so the EcoBoost advises to run higher octane since it can adjust engine parameters and make up for that loss.
