Turn signal LED replacement brand?
adamsdaddy
Orange County
My right rear turn signal died so I replaced them both with cheap incandescent bulbs. The housing were brown and blackened from too much heat. I’d like to replace them with LEDs but I don’t want to mess with splicing in a resistor if they throw an error or do the rapid blink.
I have a 2016 XLT and if you have replaced your turn signal bulbs with LEDs without experiencing the rapid blinking then please reply with the brand and model.
thank you
Robert McMillan
17plati
US
thank you
JDM Astar
Langer
Chicago
You can use forscan to disable the hyper flash when using an LED bulb.
Langer
Chicago
Thanks but I don’t own a Forscan adapter and they run $30 on Amazon which would make these $50 ($20 LEDs plus $30)light bulbs.
Return it when you’re done with it? Lots of diagnostic stuff you can do with it in addition to code alterations, too.
max357
