Brake problems
Tocs
Illinois, US
My brake pedal is hard till you start the truck then it goes right to the floor. I have bleed it several times. I replaced the brake booster and master cylinder. It is not losing fluid. Just stumped.
Yupster Dog
Super Moderator
Super Moderator
Need a little more information.
What is your truck? year? 4X4?
Before the brake booster and master cylinder, How did this problem start? Did you jump in one day and it just went to the floor? or did it start after some maintenance?
Did you just replace the calipers?
docraymund
philippines
You need to bleed it again. If you can borrow a scan tool it can also purge air out of the ABS.
