Mmart
What’s up everyone,
So I have a 2010 EB and I just found that it has a slow refrigerant leak on the long AC lines heading to the rear. I say slow because I had it charged early last summer at the local shop and they did the dye test but couldn’t locate a leak then. It worked all last year and it’s been “ok” this year up until last weekend when I decided to take it back. When it was on the lift he had me come take a look and there is a spot with some dye under the passenger side rear door. Long story short, he didn’t think it was something he’d tackle at the shop.
So here’s the questions just to help me get my head around it. If the rear line is where the leak is, does keeping the rear AC off help in any way? I know there is only a single compressor but not sure if the zones are split by anything mechanical other than the air vents/fans. Secondly, has anyone ever repaired the line itself? I don’t mean replace, I’ve seen some compression fitting kits, just trying to gauge if it’s worth pursuing. Replacing the line set looks like it could be pricey and I could live with having to charge it yearly if it lasted but I’m sure the leak will get worse so I’m trying to weigh my options.
Any input is appreciated, Thx
