Keyless ignition failure
Crusty dad
Greetings. I have a 2017 Limited with keyless ignition that will not start. Was intermittent for a few days, and today will not start at all. The key fob battery is fine. Vehicle battery is fine. Brake light switch works and unlocks shifter. All electrical comes up fine, I press brake pedal, I hear shifter release solenoid click, then click(s) in engine compartment, then silent for couple seconds, then another click and then nothing. Thank you for any guidance you can offer.
Defective battery and/or corroded and/or loose battery terminal connectors.
MikeN
Calgary, Alberta
Having the same issue. I get a click when i push the start button.
I have a 2016 max Ltd. did you figure it out?
