Truck Wont Start
Ticodillo
Midwest
Oh MY GOSH !!! You are a gentleman and a scholar!!! I'm about 15 miles from a shop and was thinking I was gonna have to tow my green beast. Simple little swap was all it took. THANK YOU SO MUCH!
JRdrivesaFord
I had the same problem. Replaced the same relay, multiple times. Now, the last time it quit, replacing the relay did not help. I replaced all relays and checked continuity non all fuses. All tested ok. Buzzing continues. Any suggestions on how I can troubleshoot to find the source of my problem? I’m deep into this Expy, don’t want to let it go.
Hamfisted
Ft Lauderdale
Fuel pump relay in the fusebox circuit board. Gotta replace the fusebox, or you can send your old fusebox out to get the relay replaced with the updated heavier duty relay. Or if you're any good at soldering you can replace the relay yourself for about $10. If you do order a new fusebox make sure of your build date ( before or after February of 2003 ) when you order.
https://www.fordpartsgiant.com/part...rical/fuses_holders_and_circuit_breakers.html
https://www.ebay.com/itm/3225992516...MIp_CWtbmJ8QIVw8fICh3GGA8HEAQYAiABEgKH1vD_BwE
https://www.ebay.com/itm/2729378564...48efa0b03d04f53b4d7b|ampid:PL_CLK|clp:2334524
hsquared360
