Bizzare Tire Issue - Fibers Hanging Out
LazSlate
Arizona
Was driving and heard a loud noise like I hit something but I am 99% sure I did not.
Pulled over and saw these strange fibers hanging out. Any idea how this could have happened.
Tire going bad, came off bead????
Super Moderator
Super Moderator
That is WEIRD! In all my time dealing with tires on the street and track, not sure I have ever seen that. I have seen grass get stuck in a tire and look almost exactly like that when hitting a curb just right, but you said fiber? Like Rubber/Fiberglass/Nylon?
I would take it to a tire shop.
Going_Going_Gone
Phoenix
maybe ran over a broom in the roadway. something not hard enough to damage rim, but deform the tire enough to grab a couple bristles.
LazSlate
LazSlate
Arizona
I think I solved this weird happening.
A Javelina
I took some of the fibers out ant they were pointed on one end and square on the other.
They were also gray with white in them and very strong.
After the big noise I pulled over and looked then drove back to the spot, albeit 5 minutes later.
Then I saw 12 Javelina's cross in front of my car a few hundred feet from the location.
So it has to be this. Guess one ran right into the side of my wheel while I was going 30mph. Must have been pretty heavy to allow the hairs to get caught in the rim.
Relived to at least have some plausible answer as riding down the highway on a tire you have no idea where these strands came from is not reassuring.
Super Moderator
Super Moderator
A Javelina
Had to look that one up! Makes perfect since in a VERY weird way!
hsquared360
