Blueovalguy
I had a fuel injector stuck open and had it fixed.The issue I have now although small is a rough idle.When I replaced the injector I also replaced the plug and fuel filter.I changedthe oil and filter to.I can't figure out what would be causing the rougher idle.It doesn't miss while driving it only when at a stop you can feel the shake.It has 139000 on it.
