C1095 ABS code
johnboneske
Ohio
I have the code C1095 and was wondering if anyone else has had it? Was told it is the Hydraulic pump motor circuit malfunction. I looked it up on the internet and found this:
ABS Controller Repair
Has anyone else had this? Any help would be appreciated!
david_jr
Hancock, MA - The Berkshires
I have seen threads like this on a lot of different Ford Forums, but it seems no one ever gets an answer. I now have the same problem and both ABS and Traction control lights are on.
johnboneske
johnboneske
Ohio
This is an old thread of mine... I do remember having to replace the whole pump/ABS block. I got a good used one from a local LKQ yard for $60, wasn't a very fun job doing it... But completely alleviated the error code and my ABS worked properly after.
johnboneske
johnboneske
Ohio
this was from my old 97 expedition...
I had a 89 Lincoln mark 7 about 7 years back, that had a check brake light on, along with no power brakes, scary! I also changed out abs unit that I pulled from pick and pull. All worked well after.
Their usually is. Your not the only one that had this problem. Habbibie one of our regulars, had his abs unit go south. These things usually come in threes, your #2!
David, before you swap out any parts, I'd do the full diagnostic that Don shot to us. It could be something simple. You didn't mention any problems like soft pedal, or pulsating, just the code. Post your findings when you, or the shop finds a solution, it will help others.
