If your only two choices are the dealer or "your mechanic" I would take it to the mechanic. Dealers simply cant be trusted to do something as simple as an oil change and do it right
Never heard of fuel diluting the oil on any EcoBoost. Got any proof like a oil analysis report ?
Good morning. I’m new to the group. I just bought a 2017 Black Expedition El Limited with 51,000 miles at carmax here in California. I was wondering should i do the oil change at a ford dealer or have my mechanic do it? Should i stick with using motorcraft or do you recommend something better?
A semi-synthetic, like what they installed at the factory is fine. For DIYer, Motorcraft purchased at Walmart is an excellent buy. Same with Motorcraft filters.
Until I can't crawl anymore, I will continue to DIY my oil/filter changes. Jiffy Lube forgot to put oil in my brother's work truck after draining it...yep, seized up 1/4 mile from the shop...and their insurance only covered the depreciated value of the old engine. I've got almost 180,000 miles on my '97 Explorer using conventional Castrol oil and a Fram ExtraGuard filter....and the same on the Expy...every 5,000.
