2001 4R70W slips in first gear but not in manual first
spowel4
Seymour
Like the title says, I have a 2001 Expedition, 2WD, 4.6L engine, with a 4R70W. When in Drive, the tranny slips when starting out from a dead stop. However if I put it into manual first gear, no slippage. Any suggestions on what might be going on?
metaldrgn
somewhere
yeah I had something similar. Clutch packs were going out (problem because of stupid previous owner). Ended up rebuilding it. I would check to see if you can find other solutions. maybe change your fluid, but be careful, sometimes that makes it worse.
Honestly it could be multiple things. Hard to tell with a quick description.
1997SCEBFEX
Northwest Panhandle
Mileage?
Last trans service to include filter change?
Any other recent maintenance performed?
on my E4OD, I have to disconnect the shifter linkage when dropping the transmission pan to service (Driver's side), and although it has a "line up" mark, it is especially important to get it just right, or I have experienced a similar problem. Any chance something is lodged?
Report back your findings.
metaldrgn
somewhere
How long does it take when you put the shifting into drive to engage drive? what about reverse?
metaldrgn
somewhere
I don't think that's an issue unless you are rebuilding it. 4R70Ws you don't have to disconnect the shift cable. When it clicks that's it shifting so 3 notches and you're in drive.
