Ended up being the caliper itself, did the brake bleed test and there was not any crazy back pressure.
nobycane74
SW FL
MY GOD......I just ended up dropping $1900 on upkeep and immediate repairs on my 01 Exp EB with 122K.
Normal maintenance stuff initially:
- Oil Change
- Injector Flush/Service
- Alignment
- Double checking on why ABS light was constantly on.
But my new 5 month old brakes were making some weird noise and I had some annoying knocking under the floor board (drivers side) going on...why did they find out:
- ALL the shocks were shot (5 year old Monroes)...replacement was done
- My ball joints were completely shot (mystery of noise)...so those were replaced
- My ABS module had completely failed...so they found a used refurb one and got it install and corrected.
- Nothing wrong with brakes they pulled them re-inspected them, cleaned them up a little more, reinstalled...no more noise.
The parts total was not that bad....but the labor killed me in the end.
RenegadeBad_Dog
South Carolina
Blacked out the chrome on the door handles using vinyl wrap. Yes it was a pain to do also this was my third time wrapping something.168db967080a90a39ccd60bc7aba89d4.jpg
Sent from my SM-G973U using Tapatalk
Plati
Had the Krown treatment for second year in a row today. Three years without Krown before that. There is a small amount of rust from before I owned the vehickel, but overall its in GREAT shape for living in Salt City USA. This pic shows the worst rust. 2014EL with 84K smiles. The rockers are absolutely pristine inside & out. I add Fluid Film treatment and even handfuls of grease in spots right before winter. The spare has gotten Fluid Film and that with road dust over last year has made a black coating that will really protect it. Will be messy if I ever have to change a flat or AAA does!
Guy said Krown went to a new formulation this year that drips less than previous
Plati
Got an oil change at Valvoline today, my standard process now that I'm OLD and decrepit.
Almost went for semi synthetic but that was $78, so stayed with conventional. $12 off coupon.
Only 4500 miles on old oil, but it looked dirty & I'm about to go on an 8K miles trip out west.
84K miles and it doesn't consume any oil between changes.
Air filter was pretty good but did that also, only 18K miles on that.
Better for breathing and I like the idea that air flow intake is …. c l e a n
Cant treat the old girl too good can you? when Momma's happy, everybodys happy
ManUpOrShutUp
PA
Picked up more gym equipment w/ the old gal. In the midst of building the home gym, I have now taken on a side gig flipping equipment. :x
I should do my oil change also (4,650 mi), but I'm beat. Maybe tomorrow.
