techdude99
I wanna try and contact mcgard, to see if a impact voids there warranty.
I'm pretty sure it's covered as long as they aren't over tightened.
140 ft lbs and above is common on trucks.150 the the tightest I have ever seen for a torque spec.
Sounds like you peeled the SS cap off and used a socket on the underlying solid lug nut. Good idea. What size socket fits that?Just for the record...maybe it'll help someone . Our 2018 Expy lugs swelled so I couldn't get the lug wrench on. I ordered replacement lug nuts from an offroad site--the web site and reviews assured me the "tuner" lugs would fit (small diameter). Since I use those on my Subaru with great results, I tried them. And...they're too small. They only engage the wheel on the very edge of the acorn seat, so I'm not comfortable with that. I'll be sending those back for more proper fatties.
Today I tried to tackle the swollen lugs. Hammered on any socket that would fit, but the stainless cap proved too tough. One of the caps spun, leading me to believe the stud had stripped out in the hub. However, I stumbled onto a thread (Ford Focus forum) where the cap spun on the lug. I used a household chisel to break open the cap and cut it away, eventually removing it from the underlying lug nut. Not difficult, but I recommend you use some painters tape to protect your wheels. So, at least my issue was just the cap.
I'll grab a six-sided socket set tomorrow with 20-22mm sockets and order the right lugs. Time to get the simple stuff squared away .
