David E
Hello to all,
Just got me a broken Expedition King Ranch 2005. About 200k on it, New transmission and engine still runs according to owner... When bought it the car would not start at all (quite a gamble there). Going through the Ignition switch --> Battery --> Neutral Safety Switch --> Starter -- I managed to find the fuse on number #34 is burned and starter relay was missing. Replaced it all and car started for few sec and died (fuse burned again).
Replaced the Fuel Pump Driver Module (thinking its shorting out) Car ran for about one min (more than before..) then again the fuse burned and car shut off.
My OBD2 is a WiFi module that would not connect while the car cannot run. Using FORScan Lite on Android I managed to get the below:
Code: P1000 - On-Board Diagnostic (OBD) Systems Readiness Test Not Complete (PCM)
Code: B1318 - The battery voltage level is too low. (4X4M DTC B1318-2F)
Code: U1900 - CAN Communication Bus Fault - Receive Error (4X4M DTC U1900-2F)
Code: U1900 - CAN Communication Bus Fault - Receive Error (ABS DTC U1900-20)
Code: B2900 - VIN Mismatch (ABS DTC B2900-20)
Code: C1805 - Mismatched PCM and/or ABS/TCS Module (ABS DTC C1805-20)
Code: C1278 - Steering Wheel Angle 1 and 2 Signal Fault (ABS DTC C1278-20)
Code: B1318 - The battery voltage level is too low. (IC DTC B1318-20)
Code: B1360 - Ignition Switch circuit open (IC DTC B1360-20)
Code: U1900 - CAN Communication Bus Fault - Receive Error (IC DTC U1900-20)
Code: B2296 - Restraint System - Impact Sensor Fault (RCM DTC B2296)
After looking further into the matter I noticed many faulty fuse boxes complains so I replaced the whole thing with one that I know in working order. Still same result -- fuse #34 burns out. Whats next?
I am guessing that there is a short somewhere that leads to the fuse (electrical is really my less comfortable area in cars), either a short or ECM. Next steps is to see how and rule out the ECM then find out where to trace that short to ground (assuming thats the case) is located and hopefully fix it.
PS. I also purchased another 2005 Expedition (Eddie Bower) for parts, so should have some options (that one runs great as it can be with a damaged engine)
Thanks you in advance for all and any help offered. Hoping someone had the same issue and found the solution.
