Don't buy a new gear shift knock, just paint it!
Max Fernandez
Colombia
Hi folks, hope you are doing well.
I've been dealing for a while with my Expedition 2007 Eddie Bauer Gear Shifter beign scratched on the top side of the chrome... paint has faded and it look horrible. I was looking to buy a new one but it was aroun USD 75$ plus shipping.
I finally took the risk of painting the faded plastic part using a metallic Rust Oleum spray can and what a result. I could not be happier and saved a lot of money. I sanded the area and painted without primer and it sticked very well. Just be caucious to mask everything really well as you will be painting inside of your car. I used a black plastic bag big enough to cover a wide area and used tape to have all in place.
See the pictures attached and let me know what you think.
Be well.
MaxRust-Oleum-Specialty-Metallic-Silver-Spray-Paint.jpg Shift.jpeg Shift1.jpeg Shift2.jpeg Shift3.jpeg
Kevin08
Illinois
Does it spray smooth coat like regular paint? I’m trying to respray the silver upper console side panels. I bought a can of metal spray that looked close to original color. It sprayed out like a gooey powder. Sprayed one panel and the whole garage is sparkling with glitter. I had to wet sand the plastic back smooth again.
Max Fernandez
Max Fernandez
Colombia
I think it will depend on the paint you use. Mine was fine, I did several coats (Like 4) and waited an hour every time I applied. Hope this helps!
