scottdm
lost me at “Canadian”. I had no issues with Canada...then I worked for Canadians. And got totally screwed by them. Ugh.
I had a Fumoto valve and ended up switching to Stahlbus which is a similar design to what TrainMaster mentioned above. I like that the Stahlbus has a threaded cap that keeps dirt out of the valve between oil changes. My Fumoto valve was getting dirt in the drain port between changes. The Stahlbus also drains more quickly in my experience due to the larger drain port & hose.
http://www.stahlbus.com/products/en/oil-drain-valve/index.php
