Hamfisted
If coolant is flowing through the radiator in a normal flow, it will automatically de-gas when it flows to the coolant reservoir tank. If there is blockage in the radiator, interfering with the normal flow, then you are not getting the normal de-gas flow the system was designed with. I would replace the radiator. A simple coolant flush is not going to fix the issue.
