Again, sport mode!
dl- Does the sport mode tighten the steering?? edit - or should i say, is it supposed to??
Again, sport mode!
My expy never had "loose" steering, though eco mode made it more vague than I'd like. BUt sport mode does firm it up, makes it heavy but progressive, and it tracks better. Honestly, I wish sport mode steering was the regular steering, I didn't like the tranny set up in sport so I couldn't use it as much as I'd like.
DL you got me messin around with the drive modes.
when i switch to sport, 4a automatically engages - (i’m guessing this is normal?.). and yes the steering definitely tightens up noticeably, especially on these Pa backroads.
when i switch to 2wd but stay in sport, i’m not so sure the steering stays as tight?
interestingly enough, when in normal mode, activating 4a tightens the steering up in the same manner as when i switch into sport mode & 4a comes on. (this i have noticed before & found myself driving all the backroads in normal+4a due to the tightened steering.)
i can’t help but wonder if it’s the physical activation of 4a that creates the tightening? or if it’s simply a power steering change that parallels the activation of 4a.
would be curious to see if someone who has a 2wd , if the sport mode tightens their steering also??? which would probably mean that it’s a separate power steering tweak within sport (& or 4a mode). i feel like if it is a stand-alone power steering tweak, then it “might” be an editable value for forscan?
any of our forscan junkies know if there is an adjustable value for power steering assist?
