Today has been a stressful day of ownership of two older vehicles. When you have an older car/truck there are going to be days like this, just didn't want problems on both in one day. Will spare you guys my Honda woes, since it is not the place.
So 1997 Eddie Bauer 5.4 with about 165,000 on it. I keep up with all of the maintenance and everything for good for a bit. Around December I got code P0401 but was on the delay on getting that fixed, since at least it ran. Now a antifreeze leak! I noticed it the day before I had to go out of town for a family emergency and said I will deal with it when I get back. Tw4o weeks later, I'm back. I added about a gallon of water to it and wanted to see if I could drive it around without more coming out. Well it's a faucet now and parked.
I am not much of a DIY guy and wanted to ask for so,e pointers on what to do or what needs to be repaired before I bring it to someone. I do not want them to see I'm a novice and overcharge me.
So I just put my phone on video and put it down the hole on inside of the engine looking for anything obvious and found what looks like the obvious problem. There is a hose that looks like it connects to the bottom of the radiator that is not connected. (Very obvious) Then I wanted to see where the other end of that hose goes, and it goes nowhere and also not connected. (???) Is this my problem?
Also another thing to add, a few months ago I was told by a mechanic that my radiator was original 1997, cracked and replacing it would be $500. This was right after I spent $$$ on brakes and $$$ on new tires. The guy said to use Bars Leaks which I did.
Also I do not drive it too often I think I did 2000 miles last year total.
Thank you in advance if you could please help.
Fist picture is the hose possibly not connected, second picture is the other end of that hose
https://flic.kr/p/2kHm59R
https://flic.kr/p/2kHmBux
