Lower spring seats -- I spent money so you don't have to
mjp2
Howell, NJ
tl;dr: just buy the Ford shocks.
I bought Bilstein shocks but don't have stock parts on my truck. Bilstein doesn't offer lower spring seats for the rear of our trucks so I took it as a challenge. In the end, you need to buy stock shocks to scrounge the necessary parts.
The spring seats that Bilstein does sell are too small for our rear coils.
They also don't come with isolators so you'd have to figure that out unless you're fine with metal on metal.
There are unbranded shocks available on the cheap that have removable lower spring seats but they're slightly larger diameter than stock so they won't work on the Bilsteins.
The Ford shocks can be had for just over $100 each and it's the way to go. You get removable spring seats, isolators, and bump stops. No need to take a hammer to loosen things up as they're new, not rusty, and are held in with the same snap ring design that Bilstein uses.
More pics to follow in a reply...
M
mjp2
Howell, NJ
Pics of the stock shocks just because.
I'll post more whenever I get around to attempting the 5100 install on the rear of my 2010.
Grover6
Calgary
Is there any reason you couldn't just buy a set of spring seats/isolators for the front and use for the rear? Asking as I will be going down this road my self soon.
M
mjp2
Howell, NJ
Nobody sells just spring seats that will work for the rear.
RobE
Destin, FL
Wow, I just threw away my stock spring and strut assemblies and replaced them with Detroit Axle parts. I suppose I should have kept them as someone could have used the parts!
M
mjp2
Howell, NJ
I did the same thing when I swapped in the Ranchos. Been kicking myself since.
Thunderbirdsport
Missouri
Did anyone search for this, and come across my thread titled "bilsteins and spring seats"? ;)
Another guy posted that he did indeed get springs seats from bilstein that WILL work on stock diameter shocks, and of course the 4600 Bilstein. Not sure if the 4600 and the 5100 have the same dia though. This will stand to have some scrutiny.
M
mjp2
Howell, NJ
Yeah, that was me who replied in there. The spring seats fit the shocks but the question was whether or not they'd work with the truck's coils. I did the legwork to confirm whether or not those spring seats would work with the coils. They unfortunately won't.
Scott Carden
Dallas Texas
I have a 2014 el king ranch 4x4. Serial #00002. The serial number is important because my truck came with test parts from for on it. The rear strut tubes were 3” diameter! Crazy huge things with different seats, springs,ect. So when I swapped to bilstien 5100 nothing would work. I bought used struts of a wreak with 48,000 miles on it for 90$ swapped the parts over I needed and junked the rest. Fronts and rears are different on these just an FYI. The rears are quick and easy . 30 minutes a side at home and 5 bolts per side including the 3 strut nuts. The front is a big more complicated and took about an hour a side but still very easy job.469620C6-E77D-4AE6-AB49-A15F8828B0D6.jpegA9DFBECC-961D-4C79-87B0-733FA965BE11.jpegFB6F64A9-82F7-42EA-89FB-5B02CEE71688.jpeg97C5D5DA-4C67-4486-A0AA-8945D655D972.jpeg
