Best way to create flat/level floor with no gaps?
Matt Conti
Detroit, MI
Just got a 2008 - and length/width are fine, but the folded flat 2nd row is still about 1.5” taller than the back 2/3 of the cargo area - and they don’t have the folding flaps like my 2000 that created a flat surface. What’s a good way to “raise” that back part to create a level floor, and fill in the gaps? My wife will need to do this for camping - so heavy plywood probably won’t work for her...
sjwelds
Kansas
For starters, the second row has a handle for cargo mode. Have you done that? Should be mostly flat if you have...
M
Matt Conti
Detroit, MI
Yes I’ve done that, it’s mostly flat but it’s still at least an inch higher than the rest. One guy built a platform box that had a “step” in it to create a level/flat/solid 49x78 (or whatever) platform. I’m just trying to do that simply, (don’t need drawers or any of that) and not heavy. If it’s possible
Hampton, VA
i know what u mean but is it a really big deal to figure out? what does she haul that would be thrown off?
tommyddsr
Portsmouth, Va
My 2009 is flat in cargo mode. I also would like a solution to fill the annoying gap (besides towels, blankets, etc.). I also had a 2000 model and the built in flaps were great. Why Ford regressed on this feature I have no idea.
M
Matt Conti
Detroit, MI
$10 foam mats from harbor frieght...to pretty perfectly level the rear area to the folded 2nd row. Then a $2000 sheet of plywood cut to length (and also cut lengthwise), to fill in the gaps. Covered it all with carpet. Instant camper for the wife/daughter.
