joethefordguy
looking for input regarding an exhaust setup for my 2004 SSV 4x4 XLT Expedition with the 5.4L 2V. I have a tuner on it already, and I have the FORSCAN adapter and SW but I've yet to use it. I'm running the 87 octane tune on it - it is barely better than the OEM police tune it had, and mileage is awful. 12mpg is a good day. I put 34" Nitto Grapplers on it, but otherwise stock (well, stock for an SSV, anyway). The plugs were replaced years ago.
it has the OEM exhaust manifolds on it, with dual cats on each side running back into a single muffler and then on out. I want to improve low end torque. NOT HP, NOT top speed, NOT drag times... JUST low end torque. I hope everyone understands that.
In looking at duals for it, I realized I will have to run pipes side by side at some point - there's just not enough room for a pipe to run down each side by itself, especially if I add mufflers, etc. Stacks might get around that, but stacks on a 4 door SUV have their own mounting issues.
Yes, I am considering CAI, an improved intake, and a larger throttle body. I've tried the GOTTS mod on an F150. It was a complete waste of time, so I'm not doing that again. I am using a (dry) K&N filter.
So, this is what I'm considering at the moment: shorty headers, 2.25" or 2.5" pipes (whatever keeps exhaust velocity up), low restriction cats, dual glass packs, and instead of an H pipe, combining the 2.5" pipes into one 3.5" pipe. One problem will be that the pipes won't be equal length due to the crossover from one side to the other. I don't know what the problems from that will be. I assume that combining the duals into one (DISO!) will gain the same advantage as an X or H pipe between duals. I assume.
Whatever the final diameter is, it needs to be twice the area (NOT the diameter) of the pipes coming back from the headers. Hence 3.5" final from the 2.5" duals, or 3.25" final from 2.25" duals... the idea is to match the final pipe's flow capacity to the dual's combined flowrate, to keep up exhaust velocity. The exhaust will dump somewhere out the side, not straight out the back.
Here is my question: What is your experience with a dual in, single out, exhaust?
thanks for your time.
jtfg
PS I have absolutely no interest in the "True Dual" exhaust argument. I could not care less. Please, Please, don't bother.
PPS the SSV is the Special Service Vehicle: Fordspeak for police car; this one was actually a fire department command car.
jtfg
