Looks like you may need to raise that WDH hitch up one hole.
It’s funny you mentioned that. I was thinking of that today while at work. I’m glad someone else thought the same. That is where the dealer set it. I thought it was one hole too low.
Yeah, I had a dealer do mine after I originally installed it and it still wasn't correct. Took me a good year of trips tweaking it to get it right where I wanted. And even now it's still a work in progress. I too have an Equalizer WDH. From your picture it looks like they choked up the arm lifting bracket pretty far forward toward the truck. It may be because of some obstruction on your trailer. I just recently moved mine to the exact Equalizer recommended position but had to reposition some wiring brackets to do so. By having that bracket further back where it's supposed to be the WDH is able to transfer more weight to the trailer axles as the way I understand it.
I'm on 7 washers now but may put in the 8th again and try to transfer more weight onto my front axle. Last time I did that it got a little squirrlly, but I've been playing with reposition weight in the camper to get to an ideal tongue weight and need to try the 8th washer adjustment again.
