Hamfisted
So question— the heater hoses. Is that some sort of disconnect where the rubber hoses meet the aluminum lines? If I could remove those hoses it would be ALOT easier to fix valve cover when I get back
Yes. Those quick connects are all the rage now at Ford and Chrysler. There's a tool of course, but basically you squeeze in on the white plastic clips and push the hose TOWARD the pipe, then pull it off while still squeezing the white clips. It's another Rube Goldberg design. Don't lose the two O-rings and the little white nylon collar on each one. The bright side is they snap back on real easy.
I use the 5/8" end of this tool....
https://www.amazon.com/OEMTOOLS-27106-Heater-Hose-Disconnect/dp/B004FEHZB4
