HELP!!!
LadyZ
LadyZ
NC
Update: ended up putting her in the shop. $753 later shes running fine as wine☺️. Thanks for all the help you guys gave me. ReUPDATE: She ran good coming home. Today its something new. Temp gauge drop back to cold and coolant lights on. I think my best option is to junk it. Ive had new catalytic converters, complete timing chains, coil packs, 3 CHT sensors, and 2 thermostats put in! Im done.
Hamfisted
Ft Lauderdale
Coolant light may be low coolant in the reservoir, or a bad level sensor in the reservoir, or a harness issue.
First make sure your coolant level is Ok in the reservoir, and the sensor is plugged in.
LadyZ
LadyZ
NC
Hello, I gave up and took it to Ford. It was none of the things the codes was for. They ran it down, was a broken wire! Thank you for your help.
geovanni
