About to buy a 21 Expedition, but…rim size?
pwbriggs23
Lafayette, LA
I’m looking for the best ride here…do I stay with the stock 18inch rims or do I get the 20inch rims? Is there a ride difference? Is it noticeable? Any info is appreciated.
dlcorbett
tx
Guessing you are looking at xlt trim. Haven't driven this gens xlt, but I've driven 2015 xlt on 18s and the 18 ltd I owned had 20s. For softest ride, 18s or ccd(22s). I don't know about xlt on 20s, but limited on 20s are firm, tight and controlled with good bump absorption. Sometimes it can be a bit too firm, but overall, one of the better riding trucks(was back in 2018/19). The 2015 expy with 18s I driven absorbed bumps as well, but it felt more isolating on different textures roads, and was somewhat floaty and bouncy on the hwy.
JasonH
Houston, TX
More sidewall usually means more compliant ride. But handling will suffer. I suggest test driving one with the 18" wheels and one with the 20" wheels.
Gary Waugh
Princeton, TX
Usually the ride height doesn’t change, when Ford offer different size wheel rims, they use tyres with different sidewall profiles, the goal being to give the same overall diameter to any wheel rim size. As stated above, the larger the sidewall (the smaller the rim size) the more compliant and comfortable the ride will be, but the steering and handling will feel less direct. The smaller the sidewall (the larger the rim size) the harsher the ride will be, but the steering will feel more direct and taught. Large sidewalls are generally good for off-reading and comfort, low sidewalls are good for sportier driving and towing (the trailer cannot push the vehicle around as much). Low profile/sidewall tyres are usually more expensive than high sidewall tyres.. hope that helps. As stated the vehicle ride height (or roof height) usually doesn’t change when selecting rim sizes offered by the manufacturer (Ford).
P
pwbriggs23
Lafayette, LA
Yes Expedition XLT trim…no offroading, 100% street driving and wanting best ride possible. Look out the window.
So 18 or 20 or doesn’t matter?
Pawpaw
Raceland, La.
My FX4 came with the 18" wheels with 275x65x18 Michelin Primacy all terrain tires. Yes they call these all terrains! Nice smooth ride and P rated so they also give good fuel mileage. Handle good in the rain but if I miss a turn and end up in a muddy cane field I'm sure I'll be stuck. Roads in South Louisiana are bumpy as hell and I'd hate to mess up the ride going with a 10 ply all terrain or hybrid tire. Sold my '17 F350 dually that was my daily driver when not towing our 41' fifth wheel that was totaled during hurricane Ida.
dwmarks
Harrisburg, PA
Had this conundrum when I was going from 18” in my 2014 Limited to a 22” option when ordered my 2018 Limited. Ultimately, went for 22” and wished I wouldn’t have spent so much mental energy on it. Ride and handling has been great for 4 years. Actually can’t even say I notice a difference (& I think the 22” rims look better!)
czego82
Florida
Where do you live? If you live in where rads are a disaster like NJ or NY then go with 18” and save the money for tires :) if you are down south like FL, you will be very happy with even 22”… very smooth
