Best headlight replacement..
Old Guy
Central Florida
Sylvania Silver Star Ultra. Available at common stores like Walmart, etc. They are brighter, and whiter which makes identificatio of objects faster for your eles. Fit the existing sockets and housing. I have them on ALL my vehicles. Run about $40 a pair. I put them in the regular, hi-beams and fog lights. Installlation is simply removing theexisting lamp, and putting in the new one, like changing a bulb.
chuck s
Some LED filament placement has gotten better the past few years. Unless the LEDs are in the same location as the filament in the halogen bulbs the pattern is crappy. I went to a local shop that specializes in lighting and audio enhancements.
Came out with wonderful HID low beams and LED high beams. 2017 reflector housings. Beam pattern seems very good. Forget the cost but these were not $20 Chinese bulbs or ballasts.
-- Chuck
Johnathan M
Klingerstown, PA
I am using these in a reflector housing. I marked the top cutoff of the old ones with tape on garage door, installed these, and it lined up perfect. Never been flashed, but way more light.
Ditto. Very happy with them. Also replaced my fogs with LEDs so they would match the color temperature of the headlights. Just make sure you get headlight bulbs that are a blade style with chips on each side rather than all around the board. That replicates the stock halogen light output placement and will keep your beam pattern correct.
bloodhound
Merica
No, all high power bulbs from Sylvania and Philips are 100% junk
Zoom in on the back of the packaging, they are rated for *UP TO* 65-200 *hours* depending on the model
That's beyond ridiculous.
Hours? Seriously? As in, depending on usage, you might kill it in *up to* one month if you use the vehicle for work or road trips??? Or maybe in *one week* if you use the highest power model and go travel or run it in a work vehicle? What a joke
I was speaking to the statement that "all LEDs" are junk.
purevw
I use Sylvania Silver Star ZXE bulbs and love them. They are slightly more expensive, and the color is slightly whiter (4200K vs. 4100K). As far as Adieu's statement, he apparently read the box and has never tried them, so likely has no actual experience to base his opinion on. In my 2011 Expy, the bulbs are 7 years old and I have driven the vehicle 80,000 miles in all weather. I have a pair in my 94 Ranger, which are 11 years old and have 140,000 miles on them in all weather. Truth be told, I have never had a Sylvania bulb fail. I would gladly recommend Sylvania halogen bulbs to friends.
Mark Buckner
st. Louis
I have been running these for several years with great satisfaction. Far better vision at night, to the point that I almost never have need to use the high beams. I get zero people flashing their lights at me because the cutoff is so good.
WarrenK
Oregon
Same here!
Since the arrangement of the LED elements match the halogen element the beam pattern is identical and DOT approved. Never buy an LED bulb for a headlight that has just a single LED element since you will ALWAYS blind people with them. Also, if the LED bulb is for a low-beam headlight then make certain the LED bulb has the same little light shade as the halogen to control the beam.
apex96
PA
Same here!
Just to clear something up… LED lights installed into halogen projector or reflector housing, that did not come from the factory with them, is not legal…. Now with that said, will you be pulled over, ticketed and your vehicle impounded?… not likely. But please check the alignment of all any LED you install into a halogen housings as the chips need to be installed in the 3 and 9 o’clock position to properly mimic the halogen filament position.
Adieu
SoCal
Not legal where?
Other than driving on the right side of the road, you'd be surprised just how few country-wide vehicle regulations we have
apex96
PA
Not legal where?
Aftermarket LED installs are not DOT legal in the United States… some countries do allow aftermarket LEDs to be installed but it’s still surprisingly few… LED tech is getting better and better but the regulations on headlight design have not kept pace. The market is flooded with absolute trash that unfortunately most people purchase crap and think it’s quality. Also if the LED is not clocked right in the housing you’ll have poor forward illumination and blind oncoming traffic due to the scattering of light.
Dcleghorn01
