Well, I just returned from the dealer where they diagnosed a vacuum leak from the front end somewhere. I was getting a weird low hum / noise when in 4A and not in 2H, so per Ford's direction, they have now permanently locked my front hubs. I was told to feel slightly more drag and potentially a bit worse fuel consumption. Still too early to tell. Don't get me started on the rear pinion seal that is leaking AGAIN. 4th time so this go around they will be changing the flange as the seal was never seated properly apparently. Also, diagnosed two other front end diff seals that need changing FFS.
