I have 106K miles on my Expedition and occasionally pull a 7,000 lb travel trailer. I frequently get a moderate engine miss under load, usually climbing a hill at 50 - 60MPH. Occasionally a check engine light, but not always. This happens more often with the trailer, but also occurs when not towing. No fault codes have registered over 20 or so incidents over the past 9 months. Shutting off the overdrive to increase the RPM helps avoid this. Plugs were changed at around 80,000 mi, but I don,t know about coils.
Since no fault codes are recorded, no one has been able to diagnose. I'm considering all new coils, wires, and plugs to deal with it.. Any other suggestions or diagnostic procedures I can try?
Thanks,
JJ
Thanks,
JJ
