Bill Balboa
Okay so I had to replace pigtails for coil and fuel injector on the passenger side cylinder 1 the thru 4.
#4 was a BEAR to say the least someone butchered the # 4 was cut, twisted together and hid in the harness, so I didn't have much to work with.
Iy used the butt splice with the solder ring in the middle and you use a heat gun to melt it.
I need to know before I put it all back together , is HOW DO I CHECK IF BOTH SIDES OF EACH WIRE THAT I USED BUTT CONNECTOR I SPOKE OF. CONNECTED CORRECTLY AND IF THERE IS A WAY TO CHECK THE CONNECTOR ITSELF TO BE SURE THEY SHOW THEY WILL WORK.
I REALLY NEED HELP QUICK IF ANYONE KNOWS OR CAN GIVE ME ADVICE.
THANKS FOR YOUR REPLY
