Turbo upgrade
Mxer0022
Logandale, NV
This should be a bolt on for the SPP and timberline models should it not? Isn't the SPP and Timberline HO 3.5 the same as the Raptor and Limited F150s?
R
rallyhard
Spokane, WA
I believe they are. Also, I see intercooler kits for sale that fit both the F-150 and Expedition, so that makes me think this kit could be a real possibility. I wonder if it noticeably increases turbo lag or decreases low-rpm power, though.
Ellison Brown III
Surprise, AZ
It might just work. Might be a few small modifications. I had to make two small mods when I installed the Full Race Feak-O-Beast kit.
JasonH
Houston, TX
Garrett has bolt on Powermax turbos for the Expedition. No mods apart from a tune needed. If you're feeling really spendy, you can get the Full Race freak-o-boost with the EFR 6258 turbos. That should be good for 700 crank hp or a lifted head, whichever comes first. This info is available via Google search if you want to read more.
rd618
new york
This is pretty enticing, I'm going to follow this.
Anyone know the drivetrain limits? Engine can likely handle the stress with the upgrades but can the driveline handle 200+ more HP passing through?
I ask because I know BMW has to use different ZF transmissions depending on the output of the vehicle, functionally they are the same, but build is more heavy duty as you upgrade.
Silver-Bullet-Bus
South Carolina
Looks like the edelbrock kit is using the same Garrett stage 2 powermax turbos available from MPT thru full race. Garrett’s should fit on a stock exhaust manifold ( which defeats the purpose & I wouldn’t do) or with the new full race form-line manifolds.
