I have a Centerline 32218. Works great stability wise. Not at all quiet during low speed maneuvers. Pretty much all the hitches work if they are properly configured.
Are they alot of work to configure / setup? Ive got 3 different cars that Ill be moving with this setup (each different length and weight) and there will be different loads in the interior of the Expy depending on what car Im trailering and where Im going.
This past run from FL to NY was not a bad trip and the trailer with the heaviest / longest car only swayed in situations caused by others.
When towing, I always try to leave a large gap in front of me in case of having to brake suddenly. But as soon as I establish a nice 5-6 car gap, someone in another lane decides he can get ahead by jumping in the gap in front of me thereby negating my buffer.
Because of this, I ended up having to jump on the brakes a few times and learned that with my particular 2017 HD Tow Expy, it handled these situations much better with the Ford Trailer sway control turned off - much better.
Im concerned about being 300lb over weight on the rear axle than the vehicle is rated for, but do you think I need to have the distribution hitch?
The need would only be when towing this particular 4800lb car, the other 2 cars are 3200 and 3400 respectively.
