My setup.
2019 Platinum with HD tow package.
-24’ Trailer with car, my tools, fuel jugs etc: ~6,900lbs.
Averaging 12.5mpg cruising around 70mph.
Using Reese weight distribution hitch with anti-sway bar.
Tows pretty well…coming from an excursion with a fully built powerstroke 6.0 with a power max turbo setup, which makes towing a breeze.
Been towing with this setup the past year and so far pretty happy with it. Not much sway driving by semis or gusts of wind, but as expected from a multi-link rear suspension it’s not as stable as a solid rear axle when towing.
Just had my thermostat replaced under warranty (noticed temps hitting 230 under certain loads while towing) and had to get the trans reprogrammed, but other then that… so far so good.
