Adding skid plates to 2018 Limited with tow package?
JONWIC
California
Anyone try the plates from the new Timberline? I would think those would bolt right up since most the changes were just cosmetic
Elcid
North Carolina
Curious on the Timberline skid plate as well. I'm sitting in the dealership looking at one right now. Seems it would work but not certain.
kmart223
PA
I need some help.... I've ordered everything on here for the factory FX4 stuff and the raptor tranny plate. The oil access part is not matching up at at all. The part number for the raptor plate was replaced with a C instead of an A.
My expedition is a 2020 Platinum Max, Did parts change from when you guys did this??
TheDoug
Mansfield, TX
Got a pic of what you received?
kmart223
PA
Here is what I received. I took a couple photos, and one for fun since it basically is an FX4 package minus the shocks lol
kmart223
PA
kmart223
PA
Well after a lot of googling I figured out my oil access panel issue. For anyone doing this now the raptor transmission cover part changed slightly. It still fits perfectly; however, the oil access panel part is different than what is listed in this thread.
The part number is HL3Z-7222-D,
Attaching hardware is:
Bolt (3qty) W500623-S439
Nut (3qty) W520813-S439
TheDoug
Mansfield, TX
Here is the raptor skid plate on mine and the oil pan bolt access panel attached
kmart223
PA
Well I finally got my oil change panel for the raptor skid plate, fits perfectly!
Underside of my Expedition is ready to go!
Now to start looking at upgrading the shocks….
DavidN
Houston, TX
So i have a 22 Limited Stealth (finally!), 3" lift, nittos. Not having a lot of luck finding anyone local (Katy, TX) that's willing to take a shot on the skid plates (including the dealer). Found this thread (thanks) and i think i might pull the trigger on some items. Do you guys have any suggestions?
Here's what i gather so far....
RCI 09-14 F150 Parts: https://rcimetalworks.com/product-category/ford/expedition-navigator/
Fill in the rest with OEM parts like these?
HL3Z-7222-A Under Cover $110.63 1 $110.63
HL3Z-7222-B Under Cover Access Panel $24.18 1 $24.18
JL1Z-5D032-A Skid Plate $50.67 1 $50.67
JL1Z-5D032-B Skid Plate $132.94 1 $132.94
JL1Z-7E063-A Plate $29.30 1 $29.30
JL1Z-9A147-A Skid Plate $78.86 1 $78.86
-W520813-S439 Damper U-Nut $1.44 4 $5.76
-W709390-S439 Damper Bolt $2.01 4 $8.04
-W704336-S439 Lower Bracket Bolt $1.44 10 $14.40
-W714338-S439 Fender Bolt $1.44 8 $11.52
-W716538-S450B Hinge Nut $1.44 8 $11.52
-W717461-S439 Skid Plate Nut $2.01 16 $32.16
-W505594-S440 Plate Bolt $2.59 6 $15.54
-W717268-S439 Sunroof Frame Screw $3.74 4 $14.96
-W717634-S439 Front Shield U-Nut $2.01 6 $12.06
JL1Z-9054-D Tank Strap $28.22 1 $28.22
JL1Z-9054-B Tank Strap $28.12 1 $28.12
othermrsikes
