Recently after shutdown I will get a significant sloshing/gurgling noise from the engine bay. I can hear it in the cab as it is LOUD. It's not constant (like water running) but almost seems like it's pulsing through ... something. It sounds like something is pumping liquid through for a couple of seconds, then it will stop, then it will pump through again. I have no leaks, no drips, no signs of any moisture exiting the engine anywhere.
It sounds like the same noise
@Shutterbug57 was referencing in this post:
I have a 2019 Limited Max 4x4. On a recent trip (02 Jan 21) from Alabama to Ohio, I noted an unusual noise under the dash on the drivers side. It sounds like liquid running through a pipe. It would act up for a minute or two, then be quiet for a while, then repeat. Over the course of an 8 hour...
www.expeditionforum.com
but there were no solutions or ideas offered.
It
has been getting warmer around here, but I've had this vehicle through 4 Texas summers since purchasing it and have never heard it before...so it's clearly new.
Any ideas from the hive mind before I take it to the dealer and they tell me they can't replicate it and I leave after wasting 3 days?
(before you ask: no, I don't have a video but I will try to get one next time)
