Let's See Those Lifted / Big Tire Gen 4s!!
M390
Believe 2017 stock Raptor wheels were 34mm offset. Just the tiniest bit of poke on my Timberline.
Expy Gator
Florida
Earlier in this thread I posted a pic with my Raptor's 35x12.50x17's on the Timberline. They are +34. It looked pretty tight - I may revisit in the future but decided to run my stock wheels with 295x70x18's
Lou Hamilton
Maryland
What is the offset of those rims? Is there any poke? I am looking at 315/70/17 on a 25mm offset.
The concept has 35/12.5/17 albeit a 2" lift wonder if those fit on the timberline with no lift.
The SEMA build uses Method 703s. They have a +15mm offset. Tires are General Grabber 35x12.5 R17s. Suspension is CUSTOM and based on the Fox Performance Elite 2.5 shocks. Penske did the build and are keeping it all pretty secret. No one has released any mods for it yet. Since the rear wheel has been kept centered, I think they also have a customer lower arm. Can't find any documentation to prove this or not.
LazSlate
Arizona
The only options for 703s I see are 0 and 25mm so I would imagine the Sema used the 25mm offsets.
Expy Gator
Florida
No - the SEMA build actually used Method 309's. I have to recheck but I believe they are a +18
Oh - Just realized you are referring to the Ford Timberline build - I was referring to the LGE-CTS SEMA build!
Expedition Dave
Expedition Dave
A Tiny Little Dot in Florida
G-day gents. Lovelt to see the 3 inch lift that fixes rear tire pull forward. Anyword on extended wheel studs? Part numbers? I have .25 spacers and want to increase my rear ones to .5 and would feel better with extended studs.
EricExpedition
Georgia
What are your 5100 set on front and rear? I’m prob going to install 5100 to my new Max limited when it comes in and put 33.xx on it on the stock 22s or swap with my wife and use her stock 20s from her 21….. also, is that St. George Island? @EricExpedition
Highest setting in front and rear. Yes it is! Had a place there for 25+ years now.
New Mexico
Yes they are 18x9, 0 offset and 5 backspacing I believe! Sorry for the late reply I just started a new job and have been super swamped!
