Lou Hamilton
I have been looking at a WDH recently and keep coming across the Weigh Safe. Without actually measuring it at the scales and just adding up the weights of what I have in my camper and around the tongue, I might be at about 550 pounds which is close to the 600 pound recommendation from Ford to use a WDH. Also, my new Timberline has much softer springs than my 2019 Limited Stealth with CCD did on the same setup and I see a lot more squat.
The Weigh Safe tells you your tongue weight right on the hitch and easily adjusts the weight distribution through the turn of a single screw.
I know it is pricey compared to others such as Blue Ox and Equalizer. However, it is less than the ProPride (which is way overkill for any towing I ever plan on doing).
Anyone try it? Thoughts? Comments?
