behattedllama
Hi All! Our 2012 Expedition threw a rod back in April. It has a 5.4l 3 valve v8 triton which is obviously deceased.
I'm toying with two very different ideas: buy a 5.4l remanufactured crate engine and swap out the old with the identical new; or consider doing a swap to a 6.8l v10.
Option 1 is obviously the safe and easy route.
Here's the details for option 2, and I need to know how problematic it would be, what all I would need to replace, etc. I can get a low-mileage (48k original miles) 2002 F250 superduty with a 2-valve v10 Triton, 4r100 transmission, transfer, case, wiring harness, etc. for less than the cost of a 5.4l crate engine. That's a 10 year age gap- going from a 3v to a 2v, but also a 6 speed automatic to a 4 speed automatic. From what I've read in other threads, the engine itself should fit in the space provided no problem. So I need to know a) will the transmission fit without modification? b) will the angle of the exhaust manifold from the F250 make it incompatible with the Expedition leading to the exhaust system running into the new components? c) will the wiring harness from the v10 be compatible with the Expy or will I need to swap dash cluster as well? d) engine mounts and tranny mounts will be moved over or replaced with new, but what else should I replace if I go this route to ensure that it's good to go? e) What issues am I potentially overlooking?
At the end of the day if I can pull off the v10 swap for a similar price to a crate engine and get the extra towing power, I would like to do it. But it's much more extensive a project than my previous endeavors, so I don't want to overlook anything. And if this is just something that's not realistically possible considering the differences, I'd like to know that too.
And yes, I could re-gear to get better towing power from a 5.4l, I could just buy a v10 truck and get rid of the expedition, etc. etc. etc. Those aren't suggestions I need, this is the specific idea I'm toying with right now.
Let me hear your wisdom!
