I tow a car hauler that's 5000lbs loaded with OEM 22" wheels and OEM Hankook tires set at the factory rated 39Psi. The tongue weight is set to ~600lbs. Smooth as silk to drive.what psi would you recommended towing something in the 4000lb range. (factory recommened is 39 psi on a 22 inch wheel.) Thanks.
