2001 rear hatch window seal leaking
03Cobra
NC
The weather strip on my window on the back hatch door leaks it looks like it has shrunk over time but its all still in one peice just seems to small to streach it back around the edges so there is gaps where water leaks. Is there a soruce for new weahter strips for this for this year or does anyone know of a good universal weather strip that will fit I can use?
Pensacola, FL
I have the same leaking issue on my 2002 (but part of mine is actually torn off. The OEM part is discontinued and no one (that I have found so far) makes a replacement. I would like to know how others solved this issue as well.
Retiredusps
N.J.
You could try the roll of weather strip that has glue on back side. auto stores or even home depot or lowes comes in many widths
ImWearingPants
