Let's See Those Lifted / Big Tire Gen 4s!!
Coop7379
Jacksonville fl
Here is a better picture of the rear wheel well. Alignment and bigger tires scheduled for Wed. I only added .7" (middle slot) with the bilstein shocks on the back on top of the Rough Country. There was only about 1/2 " of clearance at full extend between the axle and frame. Any more than that lift and it would end badly.
lefty hack
Vegas
2020 FX4 Max
I did the standard 3/2 Lift
Found some brand new OEM Raptor Takeoffs (wheels and tires) BFG 31570R17
No rubbing...a little bit of poke but not much...(which may be why they don’t rub!)
And just installed my Raptor style grille on the front!
Oh and swapped out all of headlight, fog light, and backup halogen bulbs for LED’s.
At the moment, we are calling it the RaptorEx Edition!
Where did u get and did u have to modify anything to make the raptor grill work?
Coop7379
Jacksonville fl
I do not have a raptor grill, I want one. I know one modification will be getting the front camera mounted, atleast with the one from summit
LazSlate
Arizona
Expy Gator
Florida
Is this the stock Timberline factory lift? I have a Timberline and have been looking for a while to see if anyone put 35s on it stock.
I mounted my 35x12.5x17’s on the Timberline from my Raptor. I posted pics earlier in this thread - I thought it was a little too close but they will work. I ended up going to 295-70-18 will prob upgrade in the future when more suspension options are available.
LazSlate
Arizona
Im on the fence with stock rims with 295-70-18 or the Method 703 with 295-70-17. The 703's are the only rim I could find with a decent offset. The factory is 44 and the 703s are 25. Trying to avoid wheel poke.
HtownHog
Houston
Moto metal, XD and American Racing all have the bigger offset options but they are only 8” wide wheels.
Lou Hamilton
Maryland
BTW, Timberline offset if 39, not 44. All other models are 44 as far as I know.
The 39 is stamped right on the inside of the wheel.
